JD 1020 and NH 451 sickle bar mower
hookup quest
EWB
05-25-2003 08:28:53
I just bought a 451 sickle bar mower and am getting ready to mount it on my JD 1020 tractor. I noticed in the manual that, "It will be necessary to cut 4" (10 cm) off the adjustment shafts...." for the 1020. Can someone tell me how "neccessary" this is (i.e. what happens if I don't)?. If I do cut them, will the mower still work OK on tractors like the Ford 800's? Thanks in advance for any advice you can offer.
Eric
Brokenwrench
05-25-2003 09:37:58
 Re: JD 1020 and NH 451 sickle bar mower - hookup q in reply to EWB, 05-25-2003 08:28:53
If you are going to run this mower on the 1020 you will have to make the recomended adjustments. Otherwise you will not get adequate lift,and the mower will not set level on the tractor when operating,and won�t float properly,causing plugging and skipping. These are good mowers when set up and adjusted properly,if you try to just hang it on the tractor and mow, you�ll spend more time cussing it than mowing.
