47 A question
wes
05-24-2003 20:22:41
My tractor is lacking power and I have checked everything suggested to me so far (air cleaner, points, plugs...). My question now is: Could it be that the governor isn't working? It used to be that I could idle the tractor way down and the governor would bounce it and keep it running and low idle. It won't do that now. Any Help is greatly appreciated.
Clooney
05-25-2003 06:23:50
 Re: 47 A question in reply to wes, 05-24-2003 20:22:41
Wes, a failing governor is possible but would be at the bottom of my list.
~Just watch the throttle lever on the top of the carb as the load on the tractor increases & if it moves to the wide open position the governor is controlling to properly.
~Have you adjusted the throttle rod between the carb & governor to be 1 hole short with both carb & governor held wide open?
~Have you checked the governor arm leaf spring for being cracked, weak ,or broken?
