830 pony adjustment
stevein ohio
05-23-2003 18:59:27
how do you adjust the governor on the pony motor on an 830 diesel. it runs way to fast and idles too fast too. i can hold the throttle down low enough though. any help will be appreaciated. thanks
G Taylor
05-24-2003 14:55:36
 Re: 830 pony adjustment in reply to stevein ohio, 05-23-2003 18:59:27
It's supposed to scream at about 5000 to 5500 rpm while rotating the diesel under compression.
F-I-T
05-23-2003 19:50:11
third party image
Stevein Ohio:
I think the pony on your 830 is close to the arrangement I have on my 70D.
To adjust the high speed, there is a right angle piece of steel bolted to the manifold. The governor high speed spring attaches between that and runs to the carburetor throttle shaft. The angle has elongated holes. When you slide it toward the carb, high speed decreases, away from the carb, high speen increases.
For idle, there is an idle stop screw on the throttle shaft that works pretty much like a conventional idle adjustment.
Frank-in-Tallahassee
70D // 855
steve in ohio
05-23-2003 19:51:43
 Re: Re: 830 pony adjustment in reply to F-I-T, 05-23-2003 19:50:11
thanks, ill try that tomorrow and see what happens.
Duane(Pa)
05-24-2003 19:17:07
 Re: Re: Re: 830 pony adjustment in reply to steve in ohio, 05-23-2003 19:51:43
Adjust it how you like, but you can get by with a whole lot less RPM's than the book calls for. Once you rebuild a pony, you get a lot more respect for the operation and care of the little suckers. Use the best motor oil money can buy; they only hold about a quart.
