Hi again Richard, based upon youre telling me you have good gas flow and the plugs are damp, I am going to proceed troubleshooting based on an ignition problem, but be sure you have good fresh clean water free gas: 1) First, I would start with a fresh set of new plugs, as they dont cost all that much and yours could be fouled. 2) With the new plugs and their wires attached, but the sides against the tractors frame ground and ignition on, crank her over and see if both plugs produce a good blue spark. If so, she may be fine, if not, disconenct the coil wire from the distributor (leave attached to coil) and place that end about 1/8 inch from frame and turn her on and cranks her over and see if the coil wire sparks the 1/8 gap to frame. If so but not at the plugs per above, the plug wires may be bad (replace with soild wire core wires, not carbon auto supressor wire) or theres a problem in the distributor cap and/or rotor. Clean and inspect the cap for cracks or carbon paths. 2) If still no spark anywhere: Inspect the points and if gray oxide coated but otherwise smooth and not pitted, clean/polish them but if burned or black or pitted or carboned, replace them gapped at 0.022 and see if she sparks then. 3) If still no spark despite good and proper gapped points: If you have an ohmeter or DC battery powered continuity checker, with the ignition OFF, The points should show an OPEN circuit to the metal of the distributor (ground) when they are open, but a near 0 ohm dead short to ground when closed. If they are permanently shorted out by a bad wire or bad points or spring assembly even when open, she will never run. If they dont show near 0 resistance to ground when closed, she wont run either. 4) Next be sure you have power to the coils high (not to distributor) side when the ignition is turned on. She cant run unless the swith has power and its good, so when all is on theres battery voltage on the coils high side. (Use a test lamp or volt meter) If not, by pass jump around the ignition switch by running a wire from the batterys non grounded post direct down to the coils high side (hot wiring) and see if she fires the plugs and/or starts then. If so but not if switch is on and you remove that wire (ie she runs hot wired but dies if wire is removed) either the switch (it happens) is bad or theres a blown fuse. 5) If theres power getting to the coils high side but still no spark, you can do the step 3 test a little different this way, if you have only a test light but no voltmeter or ohm meter. Turn on the ignition and the coils high side should glow a test lamp. NOW, place the test lamp over on the coils low (to distributor) side and crank the engine over and the light should flash on (points open) and off (points closed) repeatedly. If she dont flash on and off there shes never gonna run, so the points may be bad (not gettign a good ground connection) or the distributor itself dont have a good connection to ground. Try a ground jumper wire to the distributors base plate to insure the points are gettign a good ground and see if the lamp goes off when the points are closed. If so, check the distributor to frame for a good clean grease and rust free contact. If the lamp never comes on on the coils low side per the tests above, the condensor could be shorted (remove it and see if she works then, if so, it may be bad) or the points assembly or a wire to teh points shorted or the coils primary windign is open. 6) If the points and condensor are good and not shorted out and the lamp flashes on and off on the coils low side as the engine is cranked but she still wotn fire out the coil or the plugs, the coil may be bad. SUMMARY I would just try new plugs first and then make sure the coil is gettign power when the ignition is on (by pass the switch to see if its bad) and inspect and change and re gap the points if needed (a common cause of no spark), and clean and inspect the cap and rotor and plug wires, and post back what you find. Good Luck John T Nordhoff
