JD 1020 hydraulic problem
Dan
01-11-2004 09:41:02
I have a 1973 1020 diesel with a 48 loader,The loader hydraulics are plumbed corectly into the tractor hydraulic system.The problem is this,at low engine idle the rock shaft raises normally, but,at higher rpms the rockshaft somtimes,but not always,raises very slowly.If I lower the control lever then raise it again ,or make a movement with the loader controls,the rockshaft suddenly raises at the normal speed.All rockshaft adjustments were made using the JD manual,I am using hyguard oil,system is clean with a new filter, I have rebuilt the pressure control valve, inspected the flow control valve, filter relief valve and surge relief valve. Before I rebuild the rockshaft control valves, I thought I would see if anyone has experienced this problem. I would appreciate any input. THANKS, DAN
david val
01-11-2004 11:33:37
 Re: JD 1020 hydraulic problem in reply to Dan, 01-11-2004 09:41:02
you need to go over the rockshaft cylinder and valves assembly. check internal linkage, valves seats sd all seals and o rings, probably replace the pull spring.
david
jdemaris
01-11-2004 10:02:03
I was a Deere mechanic, but I'm embarrassed to say I'm not quite sure which system and pump the 1020 uses (been a few years). If it's like a 2020, 2520, etc. with a four or eight piston closed-center pump, I would suspect the stroke-control valve as a likely subject - and easy one to fix.
