Fuel additives
David
05-22-2003 07:05:54
Since unleaded fuel is no longer available, I assume some kind of lead substitute has to be added to the gas we burn in the 520. What is a good additive to use on these old JD tractors?
Thanks
tom
05-22-2003 07:49:50
 Re: Fuel additives in reply to David , 05-22-2003 07:05:54
David,
Unless you really run your 520 a lot and really heat it up[muffler turns orange], then the lead substitute is not needed. You can however, add a 2 cycle additive that helps to lube and keep things from potentially sticking. I have read this type of info. on the YT board b4.
good luck,
tom
David
05-22-2003 07:07:39
I meant of course "leaded" fuel is no longer available.
Texasdeere
05-22-2003 11:19:37
 Re: Re: Fuel additives in reply to David , 05-22-2003 07:07:39
Most of the people on this J D Forum recomend a small amount of 2cycle oil.
