4030 synchro range
derf
05-21-2003 19:40:50
have a 4030 w/8 speed synchro range transmission, likes to come out of 3,5,7 & 8 when holding back a load. any thoughts?
WTW
05-22-2003 08:00:24
 Re: 4030 synchro range in reply to derf, 05-21-2003 19:40:50
The common factor to your problem is that all the gears that you have giving troubles use the high side synchronizer. You can try and adjust but most likely will not fix your problem and may create another. The reason being is the same shift control rod that you are adjusting one way in effort to correct your problem is the same control rod that controls your low side synchronizer and adjusting it in the direction to for the high will take away from the low side. Won't hurt to try but the only real fix is a good synchronizer and shift linkage repair job. Pretty common on an older tractor with some wear on it. Good Luck, Dave W.
ET
05-22-2003 06:44:19
Lenthen or shorten the shift linkage slightly. I'm not sure which way it needs to go, but it shouldn't tak more than 1/2 to 1 turn of the clevis. The other thing is to put a new ball and spring in the shift detent.
mike
05-23-2003 16:36:10
 Re: Re: 4030 synchro range in reply to ET, 05-22-2003 06:44:19
You may look your front cab mounting over for cracks , the early 30 series bad about cracking the mounts then the cab wigglesaround some and will pop tractor out of gear.
