JD STX38 help
Gene N.
05-21-2003 11:50:00
I just got this mower. Where can I find service manuals &/or operators manual? I know for sure the brakes need to be adjusted!
Thanks!
G-MAN
05-21-2003 14:54:50
 Re: JD STX38 help in reply to Gene N., 05-21-2003 11:50:00
More than likely you'll need to replace the brake pads. That mower uses a mechanically-activated disk brake assembly on the transaxle. More than likely the pads are completely shot. And make sure you get the correct service or parts manuals for your mower. The STX38 was available as either a black-deck or a yellow-deck machine. I believe there are some differences, particularly in the mower deck. The STX was meant to be competition for the "cheap" mowers you can buy at Sears, Country General stores and the like. However, with good maintenance they seem to run forever. Probably longer than JD intended them to.
F-I-T
05-21-2003 12:11:50
Gebe:
You can order them direct from Deere at 800-522-7448.
Frank
