51 A oil pressure adjustment
Wilson5
05-21-2003 06:57:31
I want to turn up the oil pressure on my 51 A but the manual has a poor description. It looks like there is a pipe plug on the side of the crankcase you remove but then I am unsure after that. Any help would be appreciated
F-I-T
05-21-2003 07:30:57
 Re: 51 A oil pressure adjustment in reply to Wilson5, 05-21-2003 06:57:31
third party image
Wlison:
If you 've found the pipe plug, you're nearly there. Under that is a slotted hex bolt which is held from turning by a piece of spring steel against its flats. If you turn it in one flat at a time, you will raise the relief (by-pass) valve pressure. I do it with the engine warm and running.
Hope the illustraion is helpful.
Frank-in-Tallahassee
70D // 855
