Electrical Problem, Tractor will not start
tom
10-20-2003 06:52:54
Howdy All,
Tried starting the MT and I heard a very faint buzz/pop. Then pulled the starter again and nothing. The tractor did pull start when this happened just one time prior.
Here's what I did so far:
Checked the 20 amp fuse - ok
The Ammeter& generator are working, but charged the battery additionally. [6 V original Dubuque system]
Recleaned the battery terminals.
Put a wire from the starter to coil-nothing
Checked all the other wiring to ensure solid connections...
I guess this comes down to either a totally dead battery, stuck/bad starter or bad ign switch...
Any other thoughts or trouble shooting recommendations?
Just one question. If the ground [wire]connection from the dash/frame that goes to the battery's positive post touches the metal framing that holds the battery secure, can this cause a problem, either short or long term problem?
Thanks in advance for your help,
tom
Tom - Thanksguys
10-20-2003 16:37:43
 Re: Electrical Problem, Tractor will not start in reply to tom, 10-20-2003 06:52:54
Gent's,
I will try all of your suggestions and post back with the solution when I can get back out to the ranch...
Happy 2-Cyl-popping,
tom
Clooney
10-20-2003 09:59:04
Tom, probably the place to start is to verify the battery isn�t dead. That would probably be the number one cause of your problem. Either try charging it or jumping it from another 6 volt tractor.
~Those small 6 volt batteries for those Dubuque tractors do tend to die & not hold a charge after a while. In some cases they will work good one time & be completely dead & non chargeable the next. Try the lights & see if they light? Then try cranking it with the lights on.. If the lights go out while trying to crank your battery is probably either dead or bad or you have poor cable connections.
~If the battery is good then the next thing that seems to go wrong with those Dubuque tractors is the starter jamming in the flywheel teeth. Put the tractor in high gear & try to rock it & see if the engine turns over, if it won�t turn over, suspect a jammed starter. If the starter is jammed you can sometimes free it by using a hand crank, or rolling the tractor backwards in high gear. In some cases you might have to pull the starter out then reinstall it to free it up�
~Try some of the above & if it still won�t turn over post back for other problem areas�.
[email protected]
John T
10-20-2003 08:07:26
Hey there Tom, I may have just answered this same question when answerign my e mail tractor questions I think, I am a lil behind on them, I get a bunch of them and am finally gettign at them this morning so will post about the same basic answer again here.
1) A battery shop could load test the battery, be sure it has electrolyte above all the plates and none have a gray or milky color. You might try another battery or a jump and see what happens. Give her another charge to make sure and try it.
2) If all that checks good, rap the starter with a hammer just in case the brushes may be gummed up and not going tight down against the commutator and make sure the starter isnt stuck and you might loosen and re tighten the starter mounting bolts.
3) If the battery checks out okay but she still wont crank over, I would remove, clean and wire brush, and re attach each and every battery and ground and starter cable connection. Where is the ground cable atatched?? If to a seat or battery box etc try attaching it to a solid frame member somewhere and see what happens. Cheap or wimpy light automotive type crimped cable ends can have carbon under them but look fine outside. Do you have good quality 0 or 00 gauge cables???
4) If the battery and all cables and grounds and connectiosn check out but she wont crank over, remove the starter switch to be sure it or the copper looking post out the starter is not all burned or pitted or carboned up. You might try to clean and wire brush and lightly file smooth the post and try it again if it was all burned or pitted or carboned badly.
Hot wiring to the coils high input (not to distributor) side doesnt affect the starter motors abilty to crank or not, it just supplies coil energy. If turnign the switch on supplies voltage to the coil its probalby okay unless the switch contacts are burned and its a high resistance. That still dont affect the starter motor action.
A shorted to ground ground wire shouldnt hurt anything actually since its supposed to be grounded anyway. HOWEVER, if the other main ground connection is bad, it may try and draw current via any other, includign that, location which could cause arcign and heat.
If she still wont crank despite a good battery and good grounds and cable connections and a good switch and shes not apparently stuck, it may be a bad starter.
You asked and yes feel free to phone me again, but other than the above and until you check the cables and try the thigns above there may not be much I can tell you???
Let me know, any more questiosn feel free to call 812-824-4608 or post back or e mail [email protected].
Good Luck n God Bless ya there Tom
John T
Russ
10-20-2003 16:55:06
 Re: Re: Electrical Problem, Tractor will not start in reply to John T, 10-20-2003 08:07:26
Hard to start; If all the other good advice comes up short, try a fresh 12 volt car battery. Connect as per usual 6 volt layout. Do not crank for more than 5 seconds and allow starter to cool for 2 minutes per starter action.
Take out the spark plugs and hand crank to determine that engine rotation is not impeded by
cylinder rust or other problems. Good luck and may all your starts be easy ones.
Dan
10-20-2003 07:12:06
A "sizzle pop" may be a poor cable connection somewhere or a short in the starter. Positive wire to ground touching a piece of metal shouldn't hurt anything. If it is a covered wire it will eventually rub a hole. Often they use uncovered wires for the ground. Probably not the ignition switch as it really only turns the coil on, the starter will work with it being off. Could be the switch on top of the starter that the starter rod pushes against. You can pull it off and jump from battery cable to contact. Sometimes the contacts between switch and starter just get coroded and don't make good contact. You might also try loostening the starter and moving it around to see if is stuck. Next thing would be starter itself. May have worn brushes or short inside. Good luck on it, always try the simpler things first.
