630 Radiator
Greg
05-20-2003 04:37:39
My 630 has a small leak in the radiator, I was planning to remove the radiator and take it to a shop for repair, removed the hood and it appears to be a major project to remove this radiator. Can anyone tell me how much disassembly is requred to remove the radiator from the tractor, can the radiator core be removed without removing the steering assembly.
CLW
05-22-2003 19:24:09
 Re: 630 Radiator in reply to Greg, 05-20-2003 04:37:39
Greg, I replaced mine about 4 years ago. Don't remember it all but there is a lot to remove. None of it is hard, just takes some time. Best as I remember the steering shaft has to be removed but not the assembly. I don't think you can get the core out without removing other parts.(air cleaner, power steering lines, upper and lower water pipes) You are going to break a lot of the bolts anyway so you need to get it out to work on them. Have you tried stop-leak. Sometimes that works.
CLW
