Model A power lift
Alan
05-19-2003 18:13:14
I recently purchased a after market three point lift for my model "A", which I installed and it won't do anything. I know the hydraulics work because I have a disc plow that I hook to it and it works just fine. With the plow unhooked and I move the lift lever you can seem to hear the tractor loading down, is there a lever or something to switch when I want to run the three point? Any help would be appreciated.
Clooney
05-19-2003 18:52:39
 Re: Model A power lift in reply to Alan, 05-19-2003 18:13:14
Alan, it sounds like you have the incorrect power-trol adapter plugs in the two rear holes of the power-trol valve body.
~If you still have the hose adapters that were used for the remote hydraulics they won't allow hydraulic oil to flow to the internal rockshaft [3-point cylinder].
~The proper adapters you need for rockshaft operation will have OPEN fronts. The ones for the remote cylinder have closed fronts & block the oil going to the internal 3-point cylinder.
~If you have the optional selector valve in the upper P/T port you will have to remove the cap & turn the center screw to open the front of it.
~If the above doesn't get your 3-point working, post back on what you have in the rear of your P/T valve body for plugs.....
