Hydraulic Pump on D
Dave Brown
01-11-2004 05:57:47
I just took one off with the remote tower. Has anybody seen this used on a D before? What is it worth. I am not going to put it back on. It is right behind the magneto.
Dave Brown
37D
01-12-2004 09:50:30
 Re: Hydraulic Pump on D in reply to Dave Brown, 01-11-2004 05:57:47
I don't know just what you have, but John Deere sold a hydraulic kit/package for dealer & I'd guess customer installation. Basically it was the same "behind the mag" pump that was also used on the "A", "B",& "G" tractors & the seat/ hyd setup from a styled "AR".I have one of these setups, but don't have it installed yet. I'm supposed to be getting a reprint of the JD service bulletin that shows exactly how it should be done, but the guy I talked to hasn't sent it yet.
Mark Scholten
01-11-2004 15:58:14
I am not sure what you have but I am assuming you have a add on or after market hyd. setup.
If this is the case, you have a Charynn pump that goes behind the magneto. The hoses are routed through the right fender and the control valve is on the fender, the tank mounts to the inside of the right fender.
If I'm right about your set up, and you have any questions, email me back, I just put one on my '47 "D".
Mark Scholten
[email protected]
bill
01-11-2004 10:14:37
I really dont know value like others might but I would be interested in buying it 406 827 3006
Van
01-11-2004 09:47:54
Haven't seen one of those yet but I have one that goes on the PTO, even has its own built in reservior.
