Cam gear backlash
KrisA
05-19-2003 07:56:14
How do you go about checking backlash for the cam gear. In the IT manual is says something like .004 to .006. How do you measure this? Thanks
KrisA NC
Clooney
05-19-2003 17:31:02
 Re: Cam gear backlash in reply to KrisA, 05-19-2003 07:56:14
Kris, mount a dial indicator with the probe at a right angle to the cam gear teeth & at the outside perimeter of the cam gear, then rock the cam gear one way & 0 the indicator, then move the cam gear within it's play the other way & read the indicator. Do this in about 4-5 places as the cam to crank gears wear more in a couple of places due to the firing pulses. Not sure what you are going to do if you find excess wear? Most older tractors have a lot of cam/crank gear wear & asymmetrical wear on the gear teeth. Even main bearing wear effects the cam/crank gear backlash..... .....
