3020 Turbo
Joseph
05-19-2003 07:55:32
Can anyone point me in the right direction to finding a M&W turbo kit (or equivalent) for a 3020 diesel tractor. I realize the turbos are readily available from any supplier, but the rest of the parts that made up the original kit seem to be hard to locate. Any advice wouldbe much appreciated. Joe
G Taylor
05-19-2003 15:54:21
 Re: 3020 Turbo in reply to Joseph, 05-19-2003 07:55:32
You can purchase a running 4320,4620 or 5020 for the price of a complete turbo 3020 kit and installation. These tractors, particularly the 4620/5020 sell cheap. Less $$$ for the whole tractor than a 3020 engine rebuild after a failure.
Take the advice of brokenwrench
05-19-2003 15:01:44
3020 motor lightweight motor.
G-MAN
05-22-2003 10:21:36
 Re: Re: 3020 Turbo in reply to Take the advice of brokenwrench, 05-19-2003 15:01:44
I don't think that the 3020 engine was a lightweight engine, as I've seen several with many thousands of hours of trouble-free operation. But, like brokenwrench mentioned, they simply weren't up to the additional load that a turbocharger imposes, particularly on the cooling and lubrication systems. Treat them right and they'll run just as long as any other JD engine. The M&W kits aren't worth a whole lot in my opinion.
Joseph
05-19-2003 14:32:03
I have uncle in love with this 3020. we need turbo to quiet tractor because he can't take the straight pipe off and reinstall muffler. Where can we find parts?
Brokenwrench
05-19-2003 13:33:56
You might be better off moving up to a 4020 if you need extra horsepower. The 3020 engine does not respond well to turbocharging,especially under heavy loading conditions. I�ve had several through the shop with the bottom end beat out, balancers trashed, and one with the majority of the crankshaft and balancer in the oilpan(trying to pull a 5 bottom plow) The turbo gives the engine the power to lug down,and pull, but it doesnt have enough bottom end strength to take the abuse. Good blocks and cranks for 3020�s are almost impossible to find.
