JD 1010 to buy or not?
scott
05-19-2003 06:44:24
I've read alot of cons and some pros on the 1010. Sounds to me like a throw of the dice on these units with the cylinder plate arrangement. I have a chance to buy one (not currently running) with some good quality implements. I would insist of course on getting it running and checking all the operational characteristics before purchasing, especially the engine problems I've read so much about. The tractor is clean, nice tin, 40% rubber, 1400 hours, single owner, trans shift, gas, under tarp roof most of its life. Bushog, plow,harrow, rake.
Questions:
What would be a reasonable price to pay?
How much would it cost to replace the engine with the better combine unit if needed?
(I would use this figure to knock the price down.)
I see alot of model #rs stated and am confused about wich models have this poor engine design.
Is it only the 1010 & 1020 that have the cylinder plate design?
What wuold be a better series 4 cylinder model tractor to look for?
I'm in the $3-$5,000 and need implements. I mainly need it to bushog 10 acres, pop fence posts, plow small gardens and haul.
Any help is greatly appreciated.
Thank you,
Scott
Earl
10-22-2003 07:35:15
 Re: JD 1010 to buy or not? in reply to scott, 05-19-2003 06:44:24
I bought one a year ago. Paid $5000 for it. It's got a nice new paint job and a rear blade. Unfortunately it adds water to the oil and smokes. I've been too depressed about overpaying for it to even have it looked at. I'm sure I'm talking major cash to fix. Those of you who like your 1010's have probably taken good care of them.
Chuck W
05-19-2003 14:39:18
I had a late model 1010 and it ran as good as any I've seen, however the engine design is poor. It is a low torque arrangement and it requires higher rpm to obtain necessary lugging power. Compare it to a 420/430 and you'll come away shaking you head or fist...many of the people that traded in their 420/430's wanted their money back. They were used to lugging out at 600-700 rpm but don't try this with the 1010 or it will stall out. Personally if I were in the new generation I'd go on up to a 1020 diesel. Even the 1020 gas is twice the tractor. Good luck.
rob-o
05-19-2003 12:53:38
I paided 3500.00 for mine, and it had 260 hours on it. Plus a cycle mower.
Loren
05-19-2003 08:21:10
Someone below posted site information for "machinerylink.com" that I found has good pricing information. I also have a 1010. I find it to be a good utility tractor, although a lot of people would disagree. It does seems to be a bit low on power at low rpm's, I don't like the braking system, particularly the locks, and I wish mine had power steering. Otherwise I use it pretty much as you have described your needs.
Wes
05-19-2003 07:02:20
We have a 1010 on our farm and it is a great tractor. It has over 4000 hours and the only thing we have done to it is that head and that was just last year and we have had it since new. We use it to bale and haul hay, and just about any other chore we have. They are really a great tractor.
