Clutch on styled A
Jerry
05-17-2003 22:07:39
Just got this tractor and the clutch got stuck ie still engaged when I tried to disengage,
Took the clutch apart and found that the "T" bots are worn I think this is the problem but I have never had one of these before. I have a new lining for it but it appears the holes are to small to go over the T bolts. should the T bolts be tapered? Also the heads of these bolts seem to have been rubbing as they are worn quite excessivly. Is there a good place to get replacments? Thanks In advane for any help,
Jerry
Jim Jones
05-19-2003 06:27:52
 Re: clutch on styled A in reply to Jerry, 05-17-2003 22:07:39
Jerry---You'll find more than stuck bolts---are the clutch discs stuck to the flywheel,or the driven disc?...you got to check the other half of the toggle bolt(which i think they call a dog?)some times the ears on the dogs break off.The dealer should have everything you need,i had to change the toggle bolts on my A they cost me $30.each---the dogs are about the same price.. Good luck Jim.
Jerry
05-19-2003 17:47:28
 Re: Re: clutch on styled A in reply to Jim Jones, 05-19-2003 06:27:52
Thanks for the reply I need to see if my local dealer has them.
