420 a good trade for720??
Chris
01-10-2004 21:25:27
I have a 420 that was owned by a John Deere mechanic (retired). He has done alot of work and I bought it and have just painted the tractor (looks very sharp). It has new tires and when it is put back together from painting it should be as good as a new one. It is also a slant steer with alot of options. A guy wants it really bad and wants to trade for a 720 with old but shiny paint and about 50% tires. It is a diesel and it blows white smoke from the exhaust (and some other places). It also has an aftermarket wide front. Just wondering if you guys think this is a good trade or if I should hold on to the 420 for a while. I've been pondering this for awhile and just don't know what to do. Thanks for your views.
Jeremy
01-11-2004 11:31:25
 Re: 420 a good trade for720?? in reply to Chris, 01-10-2004 21:25:27
i have a 57 420 and i use it all year round its good for dragging mowing , it'll run a small disk and all kinds of things. right know we use it to feed round bales.if you need a 720 and like to work on things then its a good trade.
720Deere
01-11-2004 06:14:45
A complete overhaul on the 720 will cost nearly as much as that 420 is worth. In other words, if you want another project and have $3000-$5000 that you can part with to get it up to snuff, then go for it. A 720 diesel in that rough shape is probably only worth about $2500 unless it has a complete 3pt hitch.
White smoke = trouble, BIG TROUBLE!!
Ronnie
01-11-2004 03:26:47
Chris I'm looking for 420 if your wanting to sell please reply
JDG
01-12-2004 20:00:34
 Re: Re: 420 a good trade for720?? in reply to Ronnie, 01-11-2004 03:26:47
Ronnie I have a 420T late model complete I may sell. If interesred I am in Va.
Billyiron
01-10-2004 22:20:54
Listen closly;;;;;;;;KEEP THE 420 !!!!! !!!!
gene
01-10-2004 23:12:30
 Re: Re: 420 a good trade for720?? in reply to Billyiron, 01-10-2004 22:20:54
white smoke means that it is getting water in the cylinder, means a over haul at least an maybe a head or block. aftermarket widefront will not increase the value at all. to me a aftermarket wide lowers the value cause then i have to find another frontend for it. tires will cost you around 800 for the set. the 420 is worth alittle more then the 720 anyway. get my drift. think a little harder an you will find this a no brainer
Chris
01-11-2004 07:32:11
 Re: Re: Re: 420 a good trade for720?? in reply to gene, 01-10-2004 23:12:30
Thanks for all of the info guys. Think I'll keep it for a while, at least until I can find a good GP
