John Deere 1020 fuel guage/sending unit
Cary Cochran
05-17-2003 13:59:10
I have a 1020 John Deere that has either a bad fuel guage or a bad sending unit (in the tank). What is the best way to tell which one is bad. I checked wireing with a voltage meter and (with the switch on) the wire going to the fuel guage from the switch is hot. The wire going out isn't. I assume that the wire going out should also show 12 volts with the switch on and the sending unit (which I assume is a variable resister type unit)should be the ground. Cary Cochran
John T
05-17-2003 14:37:01
 Re: John Deere 1020 fuel guage/sending unit in reply to Cary Cochran, 05-17-2003 13:59:10
Good evening Cary, Well, you have 1 good thign going for you in that you have power to the gauge at least. Your are exactly right, the sending unit in the tank is just a variable resistor leading to ground that completes the circuit causing the needle to deflect.
Try shorting out the gauges other (non hot) terminal, and see if the needle deflects. If not, the gauge is bad. If it does deflect, but the sender dont make her work, there may be a (1) Bad or open wire down to the sender, (2) The sender itself is bad (usually an open circuit), or (3) The sender isnt gettign a good ground.
Some sending units have an additional ground terminal on them besides the isolated gauge wire (usually a black wire) and its attached to frame ground somewhere. Others rely on the tanks frame being grounded. Regardless, even if the gauge and the sender wire are BOTH good, its output still has to get grounded via and through the units variable resistor.
Try groundign the gauge to see if it deflects, and IF you can get it to deflect, then trace down to insure the sender has a good ground (you can run a ground wire to its metal or any ground lug it has to make sure) and if it does and she dont work, the variable resistor is likely bad (open).
If you replace the sender, its resistance has to match what the gauge was designed for, cuz if not, it may not be accurate. You may have to replace both with a matched set if the sender to match your gauge is no longer available.
Good luck n God Bless the USA
John T Nordhoff in Indiana
