JD 2R planter help
jeff w
05-17-2003 12:29:04
I have a model 246 planter . Im told its the same as a 290 only its for a three pt. I bought a pumpkin seed plate from JD so i could gow pumpkins but when i tested it half the seeds came out cracked or smashed. does anyone know why this is. all the parts of the planter look to be in good condition. Thanks
Mike Aylward
05-17-2003 19:13:08
 Re: JD 2R planter help in reply to jeff w, 05-17-2003 12:29:04
Jeff, it could be that with a pumpkin plate the false plate on the bottom of the hopper that the seed plate runs against needs to be turned over so the groove is up. Just a thought. Mike
Ed
12-05-2003 14:13:04
 Re: Re: JD 2R planter help in reply to Mike Aylward, 05-17-2003 19:13:08
If you have a B27436 12 cell plate you have to use a Y2630B ( a false ring ) and Y5064B Special cutoff spring.
