1941 JD B oil pressure
Tim
01-10-2004 18:54:55
just rebuilt engine, got running and oil pressure comes just over the stop mark on gauge, just wondering which way to turn screw on pump and how many turns,any advice would be appreciated. thanks Tim
Pappy
01-10-2004 23:36:01
 Re: 1941 JD B oil pressure in reply to Tim, 01-10-2004 18:54:55
Forgot to say---clockwise to increase the pressure.
Pappy
01-10-2004 23:34:39
Before you adjust the pressure, it would be a good idea to re-check the oil pressure with a good pressure gauge, just to be sure. If you have around 12 pounds of pressure, hot engine, fast idle, that should be good. If you have to adjust the pressure screw, I personally would only adjust in it about one-half turn increments to reach to desired pressure. The book says 10 to 12 pounds is ok.
