JD 70 injector pumps, help Clooney
Moye
05-15-2003 17:22:27
I have just had the injector pumps on my 70D rebuilt and before I crank the engine I want to know that the adjustments are right. I timed it according to the IT manual, but it says to set the racks at "0" when shut off, "3" at slow idle, and "11" at high idle settings. I understand how to do the settings, but I can't find any numbers!!! HELP!!! Many thanks, Moye
F-I-T
05-15-2003 18:01:54
 Re: JD 70 injector pumps, help Clooney in reply to Moye, 05-15-2003 17:22:27
third party image
Moye:
On the front side of the fuel rack, there are numbers stamped in like a ruler. 0----5----10, and such. You might have to wipe the area with some solvent and small brush if it's really black from deposits. The red arrow shows the area on a single pump rack where the numbers should be.
Frank-in-Tallahassee
70D // 855
F-I-T add'l
05-15-2003 18:04:20
 Re: Re: JD 70 injector pumps, help Clooney in reply to F-I-T, 05-15-2003 18:01:54
BTW:
I didn't mean to say there were numbers, just graduations.
Frank
Clooney
05-15-2003 18:00:58
Moye, you won't find any numbers. ~You will need a small flexible mirror & a good set of reading glasses [at least I do]. If you look closely on the little racks sticking out of the pumps you will see little hash marks [lines], those are the marks you need to look at [the 0 line], the 3rd line, & the 11th line]. Actually it should shut down on anything under the [1 line].
~Don't alter the linkage between the pumps as those should have been set during the overhaul & MUST NOT BE CHANGED. Use the governor linkage to change the rack setting as a single unit [not the individual pump settings]..
