JD D question
dale
05-15-2003 11:46:29
I have a 1936 D on steel and would like to use it for some hayrides and parades. What are my options to keep from poking lots of holes in the road?
JDBob
05-16-2003 06:18:51
 Re: JD D question in reply to dale, 05-15-2003 11:46:29
Dale,
We just took the lugs off our D and put tractor tire tread around it (Front & Rear).
Unless someone has found a perfect tire size I don't know about it a job to put that old tread around there. Cut the sidwalls out, cut the tread in half and trim down to a tight fit around the steel, then drill holes and bolt to the wheel. Takes a lot of time to make it look right and be durable. But Norman's right it runs nice down the road. If I had it to do over again I'd copy a few others ideas, they put a steel band around the outside of the center set of lugs then put a rubber ring on that, then you still have the looks of the steel lugs but the ease of rubber on the road. I'll email you a picture to look at of one that had this done.
Just my 2 cents.
JDBob
Norman
05-15-2003 17:13:07
Dale, Take the lugs off and slip the tread off an old tractor tire on it. You will have to experment to see what size. I bought a '29 "D" and it was already fixed that way. Runs quiet down the blacktop, too Later
Norman
