Governor spring
Dan in Pa
05-15-2003 09:51:22
Finally got the fan changed on the 39-B that I purchased last year, rebuilt the carb and mag, gave er 3 pulls and she fired up and runs great. One problem though, she wants to lope somewhat, in gear, moving on the level at mid throttle.Anywhere else it won't do it. I think the governor spring is weak causing this to happen. Is there anything I can do with it before I go and buy a new spring. Thanks in advance. Dan
Lee
05-15-2003 21:14:48
 Re: governor spring in reply to Dan in Pa, 05-15-2003 09:51:22
Just check that throttle is not binding at carb first. I once thought my governor was shot but turned out to be a binding throttle shaft in carburator causing whole problem. Binding linkages would do the same thing so check that angle too.
