45 A Update
dwm
05-14-2003 15:03:42
Flywheel problem solved. From the picture posted several days ago, it was hard to tell, but what was going on was the hand crank hub had been removed (forgot about that piece) from the flywheel. On these early electric start tractors, the end of the crankshaft is almost flush with the flywheel with the hand-crank hub removed. The end of the crankshaft had been drilled and tapped for a 3/8" bolt. A piece of strap iron was bolted across the two mounting holes for the hand crank hub, with the bolt through the middle of the strap going into the crankshaft to keep the flywheel from flying off. After removing this rig, we pulled the flywheel off. We have not run this tractor yet, but suspect it was knocking pretty good. Of course this strap didn't do much to solve the loose flywheel problem, but a new taper-lock hub will.
