Fan shift Drive gear removal
KrisA
05-14-2003 10:57:10
Just curious my brother and I are trying to remove the fan shaft drive gear from the governor shaft and we can't seem to make it budge. We have used heat, PB Blaster and have it on a press at about 5 tons now. How far can we go? Anyone know? Is patience in order here or should it have come loose already? Thanks for the help.
KrisA NC
Thanks Guys
05-14-2003 20:03:58
 Re: Fan shift Drive gear removal in reply to KrisA, 05-14-2003 10:57:10
We had three torches on the gear and after about 10 minutes of on and off heat she finally broke free. Scared the Crap out of me!!!!! Thanks again guys. Oh by the way we only got up to about 7,000 before she broke free. Gear is fine and in one piece. Thanks!!!
KrisA NC
Clooney
05-14-2003 15:27:10
Kris, I can't tell you how much pressure you can safely apply to that shaft but the higher you go the more chances you have to damage it or the gear. I have had a few go upwards of 15,000 lbs & that was still using heat. ~Probably your best bet is to run it up to 10-15,000 lbs & add heat to the gear & see if it will start to creep, if it does then add enough push pressure to keep it moving..
John T
05-14-2003 12:44:36
Kris, I cant tell you how much force may be required, but I can tell you we did the last one on Henry's big shop press and I bet its like a 20 ton or so. We had everything lined up and well chucked (he has like 1 inch flat steel plates with angles and round cut outs and big bushings etc) and she just finally came on out purrin like a cat in a creamery.
John T Nordhoff
