John Deer 730 diesel value
Will
05-13-2003 19:33:42
Hello everyone, I would appreciate knowing the value of my JD 730 diesel...it is a 1960 model serial no.# 7324942,it has 4400 hours on the meter and the meter and tach. still work,it has wide front,new rubber on the rears,power steering,direct electric start,starts and runs excellent,very good sheet metal,fenders,although one fender is banged up a little,and a hole on the top where a radio use to be,factory 3 point with orginial top link,field ready! thank all of you in advance,enjoy this site very much..oh..i am in central Minnesota.
Larry
05-14-2003 15:48:01
 Re: John Deer 730 diesel value in reply to Will, 05-13-2003 19:33:42
Will good org wide front $1200 org flat top fenders $1000 org 3 point with top link $1300 good running 730 el start $5000. With paint job and all the extra should be worth $7500-$10000
Larry G
05-14-2003 15:15:14
Will, There are lots of ways to look at it. I agree with the other posts. Keep in mind the add ons you have. original 3 point +/- $800; wide front if Deere square tube +/- $1200; fenders $400; new rear tires +/- $480; good running basic tractor will bring $2500- $3500 in the midwest. Add it up and see what you have.
Will
05-14-2003 10:54:14
Bill,Scott,and DDpost, thanks guys for your input..and rather humerous replies..i am grateful..no DD..that is not my 730 there in Forest Lake..as i am between Milaca,and Foley...
DPOST
05-14-2003 10:21:14
Will;
There is one simular to what you describe sitting on a lawn for sale on Hy8 about a mile east of the Hy61 and Hy 8 interesection in Forest Lake Mn. It has a sign on it that says $6900. It looks very good form the road but I didn't stop for a closer look. Was afraid I might like it ): I also would prefer pony start if I were to ever to get one.
There seem to be a few advertized in the $3000 price range. As the other guy said, if you have to get into the engine you can quickly add two or three thousand to the price. But then you can also pay a premium to get a good one and still have to spend the two to three thousand to fix it.
As for the tractor I mentioned, I think $6900 is a bit high but if it is really as good as it looks form a distance it might even be a good deal.
After my comments, I hope the one in FL isn't yours ):
Have a good one
D.D.Post
scottAR
05-13-2003 20:23:09
I've purchased two 730s in the last three years. The first one, what a bargain, sold for $2000. Then I had to put another $2500 in it to make a good servicable tractor. Since my labor seems to be worth absolutely nothing, we won't count the time I put in overhauling the motor, repairing the clutch, steering leak, and transmission, replacing the tires, flywheel, and injectors. When I bought the second one for $4050 it ran and started very well but am now having to perform surgery on the transmission, clutch, and steering bolster and replace one rear tire rim. I guess what I'm saying is that a tractor that has absolutely nothing wrong now is worth $5000 but it would have to have had a lot of real reconditioning work done on it recently before I would pay more because of all the things that need repairing after you run it for 25 hours.
bill
05-13-2003 19:54:18
This is a wide range,,but I would guess 4500 to 5750 theres lots of varibles, beauty is in the eye of the beholder or buyer,,,good luck on getting a victom ,,,er I mean buyer,;;;; bill
