Baker valve questions.
Chris
05-13-2003 18:38:27
How difficult are baker valves to install. What has to be done to put one on a 60jd. What do these things generally bring. I am wanting to add one to run a 45 loader. Thanks so much.
Mike
05-13-2003 19:29:46
 Re: Baker valve questions. in reply to Chris, 05-13-2003 18:38:27
You don't have to unhook any lines,all you need is a baker valve and the six special bolts that should come with it and two gaskets,and unbolt the six bolts that hold the valve on(drain the lift oil first)and sandwich in place.I have one on my 45W and it work great and you can still use the rockshaft,But on mine I have a hyd. bucket so I still can't use the rockshaft
bill T
05-14-2003 12:57:05
 Re: Re: Baker valve questions. in reply to Mike, 05-13-2003 19:29:46
Does anyone have a picture of a Baker Valve? I know of a derelict tractor being parted out that has a gizmo sandwiched between the tractor and a older style power lift-not power trol- with 2 hyd. lines/connectors on it. I am pretty sure it did say Baker or Davis or something like that.
Craig-MN
05-14-2003 20:13:09
 Re: Re: Re: Baker valve questions. in reply to bill T, 05-14-2003 12:57:05
I can take a picture of mine for you.
F-I-T
05-13-2003 19:52:38
third party image
Mike:
I have a 45W on my '70'D, and I used a twin-spool, mast mounted valve for the lift and hyd. dump. Since you have a Baker valve installed, you could rig something like this and have use of your hitch while using the loader.
I'll have to take your word on not removing the pipes from the Powr-Trol, but I'd think you'd just about have to pull them loose so that you could adequately clean the mating surfaces of the old gasket shellac. I know the Powr-Trol units I've had off needed a lot of work to get those surfaces really clean and ready for the fresh gasket.
Frank-in-Tallahassee
70D // 855
Hey Mike...I had a brain gag !! F-I-T
05-13-2003 20:30:02
 Re: Re: Re: Baker valve questions. in reply to F-I-T, 05-13-2003 19:52:38
I don't know what I was day dreaming about !!!
Of course you don't have to remove the Powr-Trol lines. I could have walked outside and confirmed this, but I didn't take the time !
Thanks to DaveH for correcting me, too. I think I was thinking of those times I had to remove the rear housing for lift cylinder rebuild.
Sorry again Mike. You were right, and I was very wrong !
Frank
F-I-T
05-13-2003 18:53:36
Hey Chris:
Is this so that you can use the rockshaft at the same time ? Just curious.
You could tap the Hi/Lo pressure lines that run from your governor mounted pump to the Powr-Trol unit for pressure and return for a valve on your loader without using a Baker Valve, but a Baker valve is probably not a bad way to go.
I've never installed one myself, but basically you remove the Powr-Trol unit (about 6 bolts), the hi/lo pressure pipes, then install, with poper gaskets, the Baker valve between the rear cover where the Powr-Trol had been mounted, and the Powr-Trol box. You "sandwich" it between the Rear housing and the P-trol box. The output is one the side, with a lever on the other.
I'd say the toughest part will be getting the tubing loose at the P-trol box. Take your time. A little propane torch heat helps. Replace any o-rings you come across.
70D // 855
DaveH 50
05-13-2003 20:01:17
 Re: Re: Baker valve questions. in reply to F-I-T, 05-13-2003 18:53:36
Frank,
You actually don't have to remove the hi/lo pressure lines as they are connected to the rockshaft housing, not the Powr-Trol unit. I have a Baker valve that I'm going to put on my 50 when that end of my tractor goes back together. I like them so that I can operate my 801 hitch or hook up an implement with a remote cylinder and not have to mess with changing the Powr-Trol plugs or messing with a selector valve.
To answer your question Chris about how much these bring, I've seen a couple of them sell in the $60 - $70 range. I took mine off of a tractor that I used to have and kept it to put on my 50.
Dave
