JD two cylinder injection pumps
Tony Patterson
05-13-2003 18:30:20
I am interested in finding the best repair shop to rebuild the injection pumps on my JD 720 Diesel,(black dash model) Would someone please comment on where they received good service, customer satisfaction at a reasonable price?
Thank you !!
guy
05-15-2003 08:42:14
 Re: JD two cylinder injection pumps in reply to Tony Patterson, 05-13-2003 18:30:20
I replaced the pump and injectors in my 720 last spring. I got them exchange from:
Central Fuel Injection Service Co
2403 Murray Rd.
Estherville IA 51334 712-362-4200
They are probably not the cheapest, but I got good service. I sent mine and in a few days got rebuilt exchange pumps and injectors.
They have a web site: >Link
Now>Link she makes smoke and even throws a flame from the stack when it is starting to get dark.
Eric Horne
05-14-2003 05:30:12
From personal experiance, I will tell you to stay away from Roger Marlin and the 2-Cylinder Diesel Shop in Missouri. I sent him my 820's damaged 10mm pumps and fuel rail. We agreed on a set of rebuild 13mm pumps as a replacement. Well, I got back 13mm pumps but I doubt if they were rebuilt, and I know he didn't calibrate them on a flow bench. If he would have tested them, he would have seen that both pumps leaked where they mount to the fuel rail. I tried to tighten the bolts, but they still leaked. I found that the bolts he used had bottomed out in the fuel rail.
The next set I have done will got to 2-Cylinder Salvage in Conway, MO or out to Albert. I came to this decision after speaking to both of these venders at the two cylinder expo in New York 2 years ago.
Duane(Pa)
05-13-2003 18:51:25
I had mine done (through a JD dealer)by Specialized Diesel somewhere in NY state. They work like a charm. Albert U. has been very helpful to me and is very knowlegable on the 2 cyl. diesels. Wouldn't hessitite to have him work on my pumps. He is also great with tweeking and linkage advise. There's a shop in Conway Mo. Don't know too much about them, but they advertise in Green Mag. every month.
ET
05-14-2003 04:39:20
 Re: Re: JD two cylinder injection pumps in reply to Duane(Pa), 05-13-2003 18:51:25
Specialized Diesil is in Syracuse NY.The adress is 5972 Court Street Rd. Phone 315-463-8575
Tony
05-14-2003 05:16:17
 Re: Re: Re: JD two cylinder injection pumps in reply to ET, 05-14-2003 04:39:20
Thanks for the address/phone #, Tony
Tony
05-14-2003 04:39:09
Thanks for the info !!
F-I-T
05-13-2003 18:38:06
Tony:
I would highly recommend ALbert Ulrich at Renaissance Tractor in Chehalis, Washington. He was also very helpful to me with tons of advice and encouragement as I worked my way through my '70' Diesel.
His e-mail is [email protected], and the phone number is 800-784-0026.
Please tell him that I said hello.
Frank-in-Tallahassee
70D // 855
Tony
05-13-2003 18:46:58
 Re: Re: JD two cylinder injection pumps in reply to F-I-T, 05-13-2003 18:38:06
Good evening Mr. Frank, thanks for the advice/recommendation on the pumps. I will give Mr. Albert Ulrich a call. Again, thanks for your time. Tony
F-I-T
05-13-2003 18:56:03
 Re: Re: Re: JD two cylinder injection pumps in reply to Tony, 05-13-2003 18:46:58
Tony:
You don't thank people for their time here !!
I'm gonna be all over you for advice sometime, too !!
Seriously, hope you get it fixed !
Remember, "If it Runs like a Deere, and Smells like a John..... it's a Diesel !"
Frank
