Chains or ratchet straps
Dan
05-13-2003 07:42:19
I recently purchased my own trailer and have always liked chains and binders for securing a load. But a friend of mine needed a tractor moved and insisted we use his 3inch ratchet straps. I have to admit they did a great job.I used to truck railroad ties over the road and know what problems chains and binders can give you sometimes. Now I am undecided as to what to invest in to do the job
Will P
05-13-2003 20:53:28
 Re: chains or ratchet straps in reply to Dan, 05-13-2003 07:42:19
When hauling stuff. I will chain it to the trailer and hold stuff down with the straps. Like the wind stacker of my thresher.
When hauling just tractors. I feel safer with chains.
My 2 cents.
Will P
G-MAN
05-13-2003 15:35:48
If you like the ease of ratchets and the added security of chains, try those ratcheting load binders, rather than the over-center type. They work a lot better, and you don't have to worry about a cheater pipe popping loose and kicking you in the teeth. You also don't have to worry about cutting a strap on a sharp edge. Exposure to sunlight will also weaken straps, as one of our customers found out when hauling in a 6076 for a long-block swap. The strap broke and the engine went right off his trailer when he was going around a corner at all of 10 mph. Good thing it was the junk engine that took the trip.
Scott
05-13-2003 09:24:55
Last time I checked, DMV does not recognize ratchet straps as a suitable way of securing farm/construction equipment to a trailer. At least that is what I have been told here in North Carolina. I too like the ratchet straps, but feel that the chains are safer in the long run. Never had any problems with the straps but I have seen accidents where straps failed, and chains have held under similar conditions.
