JD-H WITH TOO MUCH OIL
GERRY
05-12-2003 19:08:01
I HAVE PURCHASED A JD-H AND FOUND IT TO HAVE TOO MUCH OIL IN CRANKCASE ( 4 qts). I FOUND THE CAUSE OIL WAS GOING FROM THE HYDDROLIC PUMP INTO THE CRANKCASE. WHAT DANAGE COULD HAVE BEEN DONE? IT SEEMS TO RUN GOOD.
Clooney
05-13-2003 03:59:39
 Re: JD-H WITH TOO MUCH OIL in reply to GERRY , 05-12-2003 19:08:01
Gerry, as Frank said, the hydraulic oil was probably just engine oil & all it did was add to the crankcase level. It probably even helped as the governors didn't oil that good on the H's & that leaking pump kept a good flow of oil to the governor area. Even if they were using hydraulic oil in the pump it wouldn't have hurt anything.
F-I-T
05-12-2003 19:39:03
Gerry:
Typically the lettered series hydraulics used motor oil for hydraulic fluid, so leakage probably won't have caused you any real harm.
Hopefully someone more familiar with the "H" system will help you out.
Frank-in-Tallahassee
70D // 855
