60 wiring diagram
ron
05-12-2003 17:36:46
Does anyone have a wiring diagram for a JD 60 that I can follow ( I am a red convert so I don't fully understand the green thing)
Thanks
John T
05-12-2003 21:08:16
 Re: 60 wiring diagram in reply to ron, 05-12-2003 17:36:46
Ron, Sure, I will e mail you one. However, consider yourself forewarned there are lots of variations on different model numbers plus many tractors have been jury rigged over the years, so its impossible to tell exactly what you have. You can start with what you have and the diagram I send you, then post back and Im sure I can get the old girl up n runnign just fine.
John T Nordhoff in Indiana
Clooney
05-12-2003 17:49:31
Ron, the published wire diagrams for the 60 are very confusing as they cover multiple years & show way more than your tractor has.
~There is a slight difference in the 60 between the early & the late. I have some hand drawn more correct wire diagrams that I have drawn for people over the years so if you give me the year & type 60 you have I will try to find the closest one I have & send it to you...
ron
05-13-2003 17:11:46
 Re: Re: 60 wiring diagram in reply to Clooney , 05-12-2003 17:49:31
appreciate your response! The tractor I have is ser. #634257 I beleive a 1954. The wires are all gone so I am starting from scratch.
Clooney
05-13-2003 19:07:50
 Re: Re: Re: 60 wiring diagram in reply to ron, 05-13-2003 17:11:46
Ron, check you E-Mail for an early 60 wire print.....
