Clooney Nelp
Daniel N.
05-11-2003 11:13:54
Clooney I have a 1950 John Deere D runs fine. I notice that there is a leak behind the flywheel. I think its coming from the main bearing cover. What things should I expect?
Thanks Daniel
Clooney
05-11-2003 18:51:00
 Re: Clooney Nelp in reply to Daniel N., 05-11-2003 11:13:54
Daniel, you can probably expect to find the cork seal inside the flywheel spacer leaking, you might also find the spacer housing oil drain plugged, or at least partially plugged & there is a possibility the main bearing clearance is excessive & flowing more oil out than the slinger can handle. None of the above are serious problems. The main bearing adjustment could be a problem if the plugs & bolts are rusted.
~Probably the place to start is to just install a new spacer seal & clean the drain hole & see if that is all it takes to stop the leak [probably will].
~Don't forget to mark the flywheel to crankshaft before removal & make sure the spacer drive pin slot is in line with the flywheel pin on re-assembly, then center the spacer cover around the spacer with .003" feeler gage stock. Re-set the crankshaft end play to .005" to .010" when installing the flywheel.
~One more thing..... Be careful that flywheel on that D is awfully heavy..... ..... .....
Maybe someone else can help
05-11-2003 17:24:03
Did you ever think about that?
