2555 transmission pressure
shane silvey
01-10-2004 08:49:35
I busted a hydraulic line and was low on fluid after I filled it the light wont go out.Any help on fixing this problem. I know there is a screen and maybe I picked up some trash where is this located?
david val
01-10-2004 09:13:45
 Re: 2555 transmission pressure in reply to shane silvey, 01-10-2004 08:49:35
the screen is under a large plug on the right side of the transmission case close to the bottom. you need to drain the oil from the case before removing the plug. did you add the correct oil type? it's not very likely that the screen is klogged all of a sudden.
make sure you use the correct oil and change the filter too.(too heavy oil will not past the filter fast enough and the filter bypass valve will open and drop transmission pressure).
david
