To Pull, Or Not to Flywheel on JD A to paint
Keith
05-10-2003 20:40:02
Was wondering, is it advisable to pull flywheel on a JD A to "clean and paint", or better to let sleeping flywheels lie ?. If you pull it, How is it done. Thanks in advance
Dave K
05-11-2003 17:14:20
 Re: To Pull, Or Not to Flywheel on JD A to paint in reply to Keith, 05-10-2003 20:40:02
I did not take mine off to paint but have had the flywheel off for other maint many times. Never gave me a problem. Set up end play per the manual.
Dave
Dan
05-11-2003 13:31:12
Painted 2 JD's and left the flywheels on both times.I agree with the others,leave well enough alone. If you take your time you can probably slide some touch-up on in behind there.
Dave 2N
05-11-2003 06:24:45
Keith-
If your flywheel is tight with no slop or knocking, don't pull it. As someone below said, "let sleeping flywheels lie."
Bottomd
05-11-2003 06:11:48
Keith I pulled my wheel to clean and paint there were strips cut from a pop can put on the crank. I put them back in the best I could but could not get the thing to stop clunking so I had to get another wheel I wish I had never took it off.BottomD.
RickB.
05-11-2003 02:55:55
If the flywheel is tight and crank endplay is correct, I wouldn't move it. Seems like asking for trouble.
