Block Clearance
Tim
05-10-2003 17:51:45
I recently overhaul my MT 2 cylinder engine.Ran
it maybe 3 hours in 3 weeks.I'm getting antifrezze
in my oil.My head was milled. I found a bent head
bolt when taking my head back off.I gauged my block and have .004.Should I have my block milled
too or would new head bolts fix it??
Paul from MI
05-11-2003 20:23:11
 Re: Block Clearance in reply to Tim, 05-10-2003 17:51:45
Just my opinion, but I'd try it again with new bolts with a good sealer like Copper Coat on the gasket. This is based on you having no leakage problem before you took it apart. If there's evidence of freezing, cracks in the head, had leaks before, etc. you might want to have the head and block checked for cracks. Retorque the head after the engine is warm also. Good luck,
Paul
