Narrow front end from 20 series to 30 series
John
05-10-2003 08:52:24
Hi guys:
I was wondering if the narrow front ends are the same from the 20 to the 30 series (can I install my 4020 narrow front to a 4430?) You see very few 4430's around with a NF on it.
Thanks!
John
Brokenwrench
05-11-2003 11:59:51
 Re: Narrow front end from 20 series to 30 series in reply to John, 05-10-2003 08:52:24
If the tractor came through with a wide front, it cannot be changed to narrow front. Your only option would be to locate an entire n/f assembly at a salvage yard. This entails removing the entire front casting, steering motor,etc. As far as I know Deere never built a 44 with n/f, only 4030 and 4230 and very few of them.
John
05-10-2003 17:25:12
Ok guys, how can I tell if it has a convertible pedestal on it? I know for sure that a NF was an option from the 4030 to the 4430. I thought the 30 series was the last of the original NF's. A loca guy has a 4430 with a NF and it looks pretty sharp.
John
MIKE HANLEY
05-10-2003 19:43:14
 Re: Re: Narrow front end from 20 series to 30 series in reply to John, 05-10-2003 17:25:12
Only a guess here, but like on the 50 to 730 the steering arm for the wide fronts uses two of the four holes that the roll-a-matic bolts to. I would look and see how the steering arm bolts on and remove the bolts and if you see four holes messure the paddern. Then see if it matchs the 4 bolt paddern of the roll-a-matic.
MIKE HANLEY
05-10-2003 16:02:19
The John Deere dealer at Granton Wisconsin had a 4030 pictured in his ad last week in THE COUNTRY TODAY newspaper with a roll-a-matic and no cab or rollguard. Looked naked.
You can, IF.......................
05-10-2003 13:40:44
the aforementioned 30 series tractor is equipped with the convertible pedestal----otherwise, you cannot.
F-I-T
05-10-2003 14:28:31
 Re: Re: Narrow front end from 20 series to 30 series in reply to You can, IF......................., 05-10-2003 13:40:44
He's talking a New Generation -30 series. Were they even available with a non-convertible pedestal ?
Frank-in-Tallahassee
70D // 855
I know that, F-I-T
05-10-2003 15:14:00
 Re: Re: Re: Narrow front end from 20 series to 30 series in reply to F-I-T, 05-10-2003 14:28:31
The front end supports on the Generation II 30 series are different, depending if the tractor was equipped with the regular wide front end, or was equipped with the "convertible" option--which could be equipped with a regular double-knuckle front end, Roll-O-Matic, or a wide front end, or single front wheel. Unless a Gen II tractor is equipped with the "convertible" front end support, you cannot install a Roll-O-Matic, double-knuckle or single front wheel.
jose
05-10-2003 10:08:02
hey John your have some photo of 4030 4230 4430 or 4040 Narrow front ?
