JD A transmission repair
Diesel Don
05-10-2003 08:15:05
My loving wife bought me a JD A tractor for my birthday.It is the one I mentioned a while back on this forum with the tranny stuck in first gear.She had it delivered here and I immediately opened up the tranny cover and found the problem.The first gear sliding pinion has badly chipped corners on the teeth to the point of some being half gone.What I need from you fine folks is any pointers or guidance in that type of transmission work.I'm sure there's guys out there that have been there and done that so please,if you don't mind,share some words of wisdom with a rookie.By the way,I think the the first gear sliding pinion got stuck because a piece of metal wedged in the splines and gauled the internal splines of the gear.This will require removing the sliding pinion shaft and all the shift rails.
havvey
05-11-2003 05:35:54
 Re: JD A transmission repair in reply to Diesel Don, 05-10-2003 08:15:05
i may have parts and have rebuilt many of them first get a manual personly i like to (gut ) the whole thing and start over sometimes you dont see all that is wrong like bearings etc email me if you need to
Diesel Don
05-11-2003 09:27:54
 Re: Re: JD A transmission repair in reply to havvey, 05-11-2003 05:35:54
Thanks for the reply.I will keep that in mind.
