430 C wiring update.
MIKE HANLEY
05-10-2003 07:21:10
3 years ago I sent out the ALT to make sure it was OK and wired for single wire. From day one the crawler would drain the battery over nite. With the ALT back from the shop I thought it was the wiring. Ran it with a knife switch at the battery and pulled the switch at nite. This week I finally took the ALT to another shop and had it checked out. Turns out is was a MOTORCRAFT ALT and it was putting out 16 to 22 volts when running and when off would short out which was causing the battery to drain. It came back from the 1st shop that way and all this time I was thinking it was the wiring. 3 years is a little late to go back to the 1st shop and complain.
