Clooney John T
Marvin
05-10-2003 05:41:28
Thanks for all the information. 620 won't run is now running. I changed the ignition switch, spark plugs to autolite, oiled the cylinders, and changed the starter switch. The starter switch was partially shorting out the ignition voltage when it was released.
Clooney
05-11-2003 05:27:35
 Re: Clooney John T in reply to Marvin, 05-10-2003 05:41:28
Marvin, you're welcome.
~Sometimes it just takes a few small things to get those old 2-cylinders running again. Those starter switches are problematic when a tractor sits out in the moisture for any length of time.
John T
05-10-2003 06:35:11
Youre sure welcome Marvin and congatulations, its sooooo oooo fun to get one running. Glad we were able to lend a hand. I forget if you had the starter switch with the extra lil side terminal used to by pass the ballast when cranking ????? must have if it had some sort of short, those wires going down to that starter can get bad or shorted from rubbing or being pinched. If so, that wire (hot only when cranking) goes to either the load (non ignition switch) side of the ballast resistor or direct to the coils high (not to distributor) side terminal (same electrical point) to supply full battery voltage (not ballasted) to the coil when cranking. I ran Autolite 388 on my 620 if I recall.
Best Wishes John T
