Deere R/730 injectors
Reed
01-10-2004 07:02:57
I have bored my R out and installed a set of 730 pistons and now its time to install the 730 injectors. How do I drill the old injector holes out to fit the 730 tips? How much do I drill? Do I drill the hole all the way thru? How far should the tip protrude thru the head? Thanks
Gpower
01-10-2004 07:31:57
 Re: Deere R/730 injectors in reply to Reed, 01-10-2004 07:02:57
You will need to drill a .317 hole thru your head. Is the head off?? You can still do it with the head on, just grease up the bit end and drill slowly, and wiping the end off, and putting on more grease. Drill the hole all the way thru. If your head is off, it would be good, then you can check to make sure that the tip is thru the end of the head properly. Also check that the copper tubes are seated properly in the bottom of the head, these have a tendency to leak. The head drills out really easy just take some time and make sure you drill it square thru the old hole. You will have to get an adapter to make the bit shank long enough to get into the head, I was never able to acquire a long enough bit in that size.
Any other questions drop me a line. You wont be happy with the stock 730 tip in the engine you built. Just forewaring you.
Gpower
Scott in SC
01-11-2004 05:41:25
 Re: Re: Deere R/730 injectors in reply to Gpower, 01-10-2004 07:31:57
Gpower,
Please drop me a line also. I'm going into my R this spring, and I'd like to have the hot set up. Thanks!
Scott
Jonathan
01-10-2004 10:40:13
Gpower can you drop me a line of what tips are best Iam doing the same thing to my R right know with 730 pistons. thanks
