Gauges on a 1950 'B'
souNdguy
10-20-2003 05:52:48
What were the orm gauges on the 1950 'B'.
I currently have an oil pres, ampmemter, and water sensor gauge. There is a space for another gauge at the bottom of the dash.. but is empty.... what went there?
thanks
Soundguy
F-I-T
10-20-2003 06:33:17
 Re: Gauges on a 1950 'B' in reply to souNdguy, 10-20-2003 05:52:48
SoundGuy:
Originally, the "B" had Oil, Amps, and Water Temp. Maybe someone had an hourmeter in there at one time, or large ignition switch?
You can probably find a used dash panel if you want to return it to original.
Frank
tom
10-20-2003 09:33:04
 Re: Re: Gauges on a 1950 'B' in reply to F-I-T, 10-20-2003 06:33:17
Soundguy/Frank
I do not have any idea if this is applicable to the B or not, but for the MT, there are some extra holes in the dash too: (1) for an All-Fuel option and (2), the other for a radiator attachment option.
If the B has these or other type options, then that is probably the reasons for the holes. I am rock-solid on the MT's options, but just logically speculating with the B.
Good Luck,
tom
F-I-T
10-20-2003 11:27:57
 Re: Re: Re: Gauges on a 1950 'B' in reply to tom, 10-20-2003 09:33:04
third party image
Tom:
Here's a pix of a late "B" dash panel. I took SoundGuy to mean he had a fourth hole the size of a gauge at the bottom. There is an all-fuel selector rod hole on the lower left, but it's not anything more than maybe a 1/4" or so hole.
Frank
tom
10-20-2003 11:54:48
 Re: Re: Re: Re: Gauges on a 1950 'B' in reply to F-I-T, 10-20-2003 11:27:57
Hi Frank,
I would concur with your statement...maybe a hour gauge or fuel gauge...thanks for the clarification.
tom
souNdguy
10-20-2003 06:36:32
Ok.. so I do actually have all my gauges.. someone just added 'smoething'. If I can't find a good blank out, or repair the dash, I may have to try to find one.
thanks for the info,
Soundguy
