B Rocker shaft
Greg
05-09-2003 09:31:04
The left rocker shaft on my 52 B can be moved in and out +/- 1/4" and can be turned back and forth slightly, is this normal play in the shaft or is there a bearing, gear or shaft problem.
Clooney
05-09-2003 11:17:21
 Re: B Rocker shaft in reply to Greg, 05-09-2003 09:31:04
Greg, that's about normal for the old B.
~As long as both shafts go up at the same time & are reasonably in time with each other you are good to go....
