JD M Hand Crank Dimensions
jerry
05-09-2003 08:50:29
Does anyone have a handcrank for a JD M tractor that they can measure for me? I believe I have found a crank for my M, but I need the dimensions before I buy it to be sure it will work. Thanks.
tom
05-09-2003 12:44:20
 Re: JD M Hand Crank Dimensions in reply to jerry, 05-09-2003 08:50:29
Jerry,
The parts book does not give dimensions..However, the parts number for an M is AM 223 T. You can check with your dealer and see if they have some numbers for you.
Another alternative is to borrow [if not too far to return] and see if it works...good luck
