Hey Dave, you say its a magneto, so I will proceed assuming its really that and NOT a Wico XP Battery powered distributor. If its a Wico brand model C or XH magneto, here are a few troubleshooting tips. 1) Does it produce a good sharp snap/click each 180 of flywheel rotation????? If not, shes never gonna fire at crank speeds. If not, the trip dog assembly in the rear (where mag couples to governor gear) may be stuck or rusted in which case a cleaning and lube may fix the problem. Look for this potential problem first. 2) If she does snap but wont spark, is there any kill switch stud or wire or push button on the side of the mag????? ?? If so, any wire to it can NOT be shorted or it kills the spark. I have seen the studs themselves go bad or their insulators shortign them to ground which kills the spark. Also, inside the mag any wire to that stud can NOT be touchign ground. Its supposed to have an insulated non grounded wire hooked to the points. 3) If the plugs wont fire, will the end of the plug wire all by itslef spark if placed within 1/8 inch of the tractor and the mag snaps????? ?? If so but not the plugs, the plugs are bad. Be sure the wires are not broke or leaky and are wire core, not auto carbon suppressor wires. 4) Make sure the points are not gray oxide coated or burned or pitted and open to around 0.015 on high cams. 5) Be sure the condensor wire is not shorted or frayed. 6) If she snaps loud and the points are clean and gapped and theres no shorted kill wire or stud or condensor wire and she wont fire the plug wires assumignm they are not broke or leaky, the rest of the mag could still be okay but theres a cap or rotor problem. With the cap removed, atatch a wire or paper clip from teh mags metal side frame to within 1/8 of the coils side output button/terminal and when the mag snaps, a good blue spark should jump that gap. If so but not out the caps terminals via a wire to 1/8 of frame, look for a cap problem like oil or cracks or carbon paths and be sure the lil spring in the cap is making contact with the coils side button/terminal. If its not, no spark out the caps terminals. Theres more but its late and Im going to bed lol. Post back any more questions and assumign its really a mag, regardless of brand, if she dont wind and spring and trip a good sharp snap shes never gonna fire at crank speeds, but could still start and run fine if pulled if all else is okay. John T Nordhoff in Indiana
