Changing Hydraulic Fluid on my 40
Tony
05-08-2003 13:22:09
Can someone advise on how to change the hydraulic fluid on my model 40? It appears that the cap to fill it is directly under the seat but I am not for sure where the drain plug is. Also, what type and how much does it hold? Thank you in advance.
Thank you, Wayne in Ten.
05-09-2003 12:37:28
 Re: Changing Hydraulic Fluid on my 40 in reply to Tony, 05-08-2003 13:22:09
You always give me good advice.
Wayne in Tn.
05-08-2003 16:48:37
Tony, looking at the lift unit from the rear: down low, on the left, will be a small pipe plug, it can be removed with a small crescent wrench. This will drain the lift, you will still have some left in the pump and lines, you can spin the engine over a few times to get most of it out. Then look over to the upper right on the rear of the lift housing, should be a small petcock, open this and fill the unit until it runs out this petcock, then it is full. Pour in at the cap in front of the seat. Deere says to use non-detergent 10W motor oil. This is the cheap stuff available from WalMart or any parts store. It will hold about 5 quarts.
