Gray oil
Dave
05-07-2003 17:54:51
I changed the oil on my JD40S last week and it was very gray looking what would cause this ND oil or water in the oil I put 30HD back in it is this ok? thanks
EJ
05-10-2003 11:47:22
 Re: Gray oil in reply to Dave, 05-07-2003 17:54:51
A good way to tell if it is water is to let it stand for a few days and slowly loosen the oil drain plug so there is a slight drainage coming out. If there is water in the oil, the water will come out before the oil. If only oil comes out, you are OK. If water comes out - you have got other troubles.
Loren
05-08-2003 08:27:31
Here is a wild card for you. MANY years ago I worked as a VW mechanic (air cooled engines, of course). When people would bring in a car needing engine work, the first thing we would do is pull off the filler cap and look at the inside of it. If it was coated with thick, gray-brown sludge, we knew before we even asked what kind of oil they were using. It was always Standard Oil/Amoco. Having said that, I doubt if oil brand is your problem if all the oil drains out looking gray and murky. Sure sound like anti-freeze mixed in to me.
John T
05-07-2003 18:08:27
Hey Dave, A gray milky looking oil is usually a sign of the presence of water. Depending upon how much, it may be from condensation or rain got in orrrrr r worse things like leaky head gasket or a crack in the block or head. After the oil change and the old girl not left to sit out, keep an eye on the coolant level and if she grays again and the coolant goes down, you may have a problem, maybe a head re torque could help????
Is she runnign hot or loosign coolant???? Hot combustion gasses in the coolant heats her up fast and another tell tale sign to look for is the presence of a lot air bubbles rising to the top of the radiator, which is air and/or combustion gas escaping somewhere into the cooling system.
John T Nordhoff in Indiana
Wayne in Tn.
05-07-2003 18:04:53
Dave, gray or milky color oil means water in it. Could be a cracked head or block or head gasket. If it does not reappear after changing the oil, it might have been rain water entered the breather pipe. Check for loss of water in the radiator. Also check the water in the radiator for the presence of oil, if so, then there is a crack somewhere or a blown head gasket.
