Is there an easier way to do this?
Bryan
05-07-2003 06:20:16
My '46 A has oil pressure now, but the air cleaner is nasty. All kinds of critters fell out of the cup. Is there a way that I could clean the filter canister without removing the hood and tank? I had a dream last night that I was kicking the rump of the JD engineer who designed that part of the tractor.....
AlbertoV05
05-07-2003 18:15:09
 Re: Is there an easier way to do this? in reply to Bryan , 05-07-2003 06:20:16
Not sure about an A, but it CAN be done on a 60. Clooney is right on the money with his advice (as usual)! : )
Link
Clooney
05-07-2003 10:44:57
Bryan, if you try hard & long enough, & have small hands you can work that air cleaner out of there. [that's if the bolts aren't too tight or rusted].
~It will take much longer than pulling the hood, & you will end up with sore cut hands.
~You will have to work a wrench up over the top & work the bolts out evenly a little at a time so the air cleaner drops down as you undo them.
F-I-T
05-07-2003 06:47:07
Bryan:
In a word.....No. The best way for you to clean it properly is to remove it, and that means the hood.
As far as kicking the engineers rump, he'd probably tell you that his method worked for 57 years without service, and that ain't all bad. The problem is that no one before you chose to clean out the aircleaner when they had the hood off, and I'm betting in 57 years, it was off a time or two.
Frank-in-Tallahassee
70D // 855
Bryan
05-08-2003 06:28:55
 Re: Re: Is there an easier way to do this? in reply to F-I-T, 05-07-2003 06:47:07
Thanks guys. I think I'll remove the hood.
