JD 60 Hydraulic Outlet Leak
JKC
05-06-2003 19:33:11
I have a 1953 JD 60 that has two outlets out the rear for hydraulic hose hookup to remove cylinder. These outlets are connected to the tractor by short metal tubes that have threads on them on the tractor end. I have quite a leak from one of those, with the leak being on the tractor end where the tube meets the tractor. Is there a seal or gasket that is suppose to go in there, one that is subject to leaking, or should I be looking at some other solution. Any help would be great. Thanks.
F-I-T
05-07-2003 06:42:53
 Re: JD 60 Hydraulic Outlet Leak in reply to JKC, 05-06-2003 19:33:11
third party image
JKC:
There are two small O-rings in each bore that are leak prone. When you remove them they will likely be brittle and flat.
The image is from a "G", so disregard the outer large o-ring.
You can use the search function here to find replies to problems simliar to yours. The discussions include how to fabircate tools for the fix, along with how to hold your mouth in the correct position. :)
Buy extra o-rings so you don't have to search for the one that you drop and it rolls under the tool box !
Frank-in-Tallahassee
70D // 855
