Hi Kilian, Well, if the generator does indeed run like a motor when you apply power to it, that tells me the armature and commutator and brushes are basically good. Then, the fact that she slows down when the field is grounded, tells me the field windings are probably good and intact. Sooooo ooooo Im thinking you may have a cutout relay and/or wiring or ground problem. Heres some things to try. First, be sure the belt is good and tight and the belt is not slick and glazed. 1) Be sure the generator is getting a good ground connection by running a wire direct from the batterys grounded terminal to the frame of the generator and see if she will charge then. 2) If she still wont charge, leave the generator frame ground attached, and ground the field post (even though you already tried it once, try again) 3) If she still wont charge even with the field grounded, by pass around the cut out relay i.e a wire off the gens A post over to the battery side of the cutout relay and see if she charges. Thats the same effect as the cutout relay were closing. It shouldnt close by itself until the gens output voltage rises higher than the battery if its okay and working. 4) If she still wont charge, are you sure the wire on the battery side of the cutout relay is ALWAYS HOT and has a good continuous path to the non grounded battery terminal????? ? It cant charge the battery if its not got a connection to it. The wire on the battery side of the cutout relay must show battery voltage relative to ground. It gets to the battery through an ammeter if you have one, and then either to the starter post or direct to the battery itself. If it has an ammeter, it should read and ohm out like an almost dead short 0 ohms. If one side of any ammeter shows battery voltage, but none on the other post, the ammeter is bad open and the generators output is never gettign to the battery. If the generator is turning, and its well grounded, and the field post is grounded, and theres battery voltage on the battery side of the cutout relay, and theres a good connection to the battery via any good (NOT OPEN) working ammeter, and she still wotn charge, I suspect the generator may be bad EVEN THOUGH MOTORING USUALLY MEANS THEY ARE GOOD. If its a 3 brush generator, the closer the 2 brushes are the higher its output, but even if set away, it should still charge. Try this and let me know what you find. You may well just have a bad or shorted wire between the cutout relay and any ammeter to the battery terminal somewhere which is drainign the generators output and pulling it down. Also, what condition is the battery in??? a dead or shorted cell in it can wreak havoc on the charging system. Try things with all other loads disconnected like lights etc which could be shortign things out. God Bles the USA John T Nordhoff in Indiana
